Studking42
Feb 08, 2023Aspirant
orbi RBR 750. strong signal, poor internet
my wifi works fine in my remote building but not in my home. Same router source. signal in home shows strong. ??
Feb 08, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices do you have connected?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- Studking42Feb 08, 2023Aspirant
Thanks. I will try some of these suggestions.
Distance between server and satellites has worked fine for last year or more. closest neighbor is 1/4 mile, so not a factor.
- FURRYe38Feb 08, 2023Guru - Experienced User
We don't know that distances so please give feedback for that. Thanks.
