Studking42
Feb 08, 2023Aspirant
orbi RBR 750. strong signal, poor internet
my wifi works fine in my remote building but not in my home. Same router source. signal in home shows strong. ??
Feb 09, 2023Guru - Experienced User
You really didn't give us much to go off.
1. what modem/gateway is the router connected to?
2. You put it works in a remote building but not your home. How do you have it laid out.
Modem (model)--->RBR750 (in home? in remote building)---connected how----->to satellites (in home/remote)
You need to lay out what your network is, how you have everything attached, and more details on what you actually get.
Poor internet doesn't say much. What actual speeds are it in each? Is it using wireless backhaul? Wired? Etc.
The more you tell us, the better we can help.
