Timothy88
Apr 06, 2022Luminary
Orbi RBR 752 only testing @ 940mbps Xfinity modem tests over 1 Gbps
Performed a speed test with my Orbi RBR 752 and with an Xfinity supplied modem and the Xfinity modem outperformed it. The Xfinity modem would reach speeds of 1.2 Gbps when the Orbi would max at aro...
- Apr 06, 2022
I forgot I upgraded my cable modem and it has a 2.5 gig port so link aggregation isn't an option. Right it's shared bandwidth. And honestly we don't notice any real slowness, so at this point its really about whether xfinity is being honest in what they say they are delivering. Its a shame I bought the 750 and then the 850 came out.
Thank you for the responses.
Timothy88
Maybe I should have phrased my question differently. Why do both pieces of equipment with 1 Gigabit ports report different speeds with one matching the highly sophisticated Fluke meter and the other coming in below?
Xfnity's device specs on the port are 1 Gigabit same as Netgear. Are they 'fudging' numbers on the speed test? Although with all of the issues Netgear has had with firmware are they trustworthy? I know in previous releases speeds were not being reported correctly.
- Model Numbers: TG3482G and CGM4140COM
- Friendly Model Name: XB6
- Gigabit Ethernet Ports: 2
- Dual-Band WiFi Option: Yes
- 2.4 GHz Connected Client Limit: 30
- 5 GHz Connected Client Limit: 75
- Maximum Data Throughput: 1 Gbps
Apr 06, 2022Guru - Experienced User
If you're running the speedtest on the built in speed test, the xfinity device has its own internal modem. And that internal modem can get faster than gigabit speeds. The modems sides have been able to get faster than gigabit for quite a while but its the ethernet interface most test off. Its ethernet can't put out faster speeds than the 940mbps but its internal side can. So you'll see greater than gigabit on any internal test that hosts on the modem/router combo device versus to a connected devices (computer/pc).
Same with most fluke meter's test directly onto the coax line and test that. Its not testing your actual usable bandwidth.
- Timothy88Apr 06, 2022Luminary
I am running the speedtests directly from the routers. I did not try the speed test by using the app from my PC.
OK. I get it now with the overhead and losses. So they are reporting what the coax is giving instead of what your real speed through the ethernet interface is (kind of cheating). Obviously the Netgear is has to rely on the ethernet interface. So in order to get better than 1 gig I'd have to go with a router with a 2.5 gig port or use link aggregation?
- plemansApr 06, 2022Guru - Experienced User
correct. Starts getting a bit pricey when you get into 2.5gig equipment.
Plus many only have 1x 2.5gig port. So even if your internal speeds are 2.5gig, their output is only 1 gig.
There's a few exceptions to that like the CAX80 that has its own internal modem so can get faster speeds and then has the 2.5gig port to connect something to it. But unless you have a 2.5gig switch (expensive as well), you're only going to get 1 device that gets those speeds.
I have 1.4gig speeds and can't say I need that fast or even use it the vast majority of the time.
