jobyfam
Oct 07, 2022Guide
Orbi RBR 850 and Australian NBN
Hi, this is my first post here. My question is can an Orbi RBR 850 connect directly to an Arris CM8200 Cable Modem? I'm in Australia, and my current setup is a NBN Arris Cable modem connected to my I...
CrimpOn
Oct 07, 2022Guru - Experienced User
Will take just a minute to find out, as long as the Orbi is in 'router' mode. My guess is, "certainly."
jobyfam
Oct 07, 2022Guide
Thanks. That would be great. I am apprehensive concerning all this stuff as our internet access here works fine at present, even though it looks like I haven't set it up correctly. I am just wanting to get this Roon Arc app accessible remotely. I also want to get the Orbi working to it's best capabilities. I just thought after reading all the setup needed to placing the existing setup into bridge mode (, and all previous settings being wiped if I later disabled bridge mode), just hooking the Orbi up directly to the NBN modem may be the easiest option. If I ever needed the ISP's Modem /Router again, I could just plug it back in as it was before? I'm just not sure how complicated this direct hooking up orbi to NBN modem is.
