muusicman
Jul 28, 2023Aspirant
Orbi RBR 850 and ORBI RBS850 Ping on wired desktop computer good???
I have the RBR850 Router and RBS850 Satellite. I have my PC directly wired from the router to the Ethernet port on the back of the PC tower. The speeds are good. 943.72 down and 939.08 up. I have Fibe...
CrimpOn
Jul 28, 2023Guru - Experienced User
muusicman wrote:
It’s a model 4640X Roku Ultra. When I do a speed test on it it says it’s getting 93 Mbps. I think the max on this device is 100.
This is correct. See this web site:
https://www.bhphotovideo.com/c/product/1292119-REG/roku_4640r_ultra_streaming_player.html/specs
This old Roku has a 10/100 Ethernet port, which limits speed to (slightly under) 100Mbps.
It could be that the WiFi performance will be greater than the wired performance.
Although.... streaming 4K video requires approximately 25Mbps. It may take a while to start streaming, but one it begins the speed limitation should have no effect.
muusicman
Jul 29, 2023Aspirant
I guess I just assumed everything would be lightning fast with fiber internet.
