ToxicMan
Jul 08, 2020Tutor
Orbi RBR 853 in AP Mode and Wired Backhaul. Satellites Aren't Detected Through a Switch
Read the entire thread and got some great tips. Now I can safely request an RMA for my brand new RBR853.
The RBS850s will not appear as connected satellites when they are attached through a switch. I found this article that clearly says they should be fine, and the RBS 850 is listed as a supported client for the config.
Here is the link to connect a wired backhaul according to approved NetGear Technical docs
I replaced an existing RBK53 setup and cabled it exactly in its place with no changes.
Setup:
Unifi Managed Switches
Frontier FIOS with G1100 Router
Scenario 1 (Existing RBK53 Cabling Setup:
* Orbi Router AP Mode (WAN port) -> Unifi Switch -> G1100 Router LAN port
* Orbi Satellite (LAN port) -> Unifi Switch
Outcome:
- Satellites are not listed in "attached devices" => no mesh;
Read some threads, tried some stuff. Had this outcome
Scenario 2:
* Orbi Satellite (LAN port) -> Orbi Router AP Mode (LAN port)
Outcome:
+ Satellite is listed in "attached devices" => mesh;
Scenario 3:
Setup:
* Orbi Router (LAN port) -> Unifi Switch -> G1100 Router LAN port
- No internet detected within Orbi RBR UI.
What is the model# of these switches?
IF there managed, please disable all IGMP and green ethernet protocols on these switches. There are known problems with managed switches with Orbi systems.
- ToxicManTutor
No EEE on the switches and no IGMP either.
I have a three floor home with the top and middle floor ethernet runs terminating into a
UniFi Switch 8 POE-60W
Version 4.3.13.11253
Board Revision 8These two Unifi switches then uplink to my tech closet on the ground floor where I have a
Model UniFi Switch Lite 16 POEVersion 5.6.0.11463Board Revision 8The tech closet has my ONT and G1100 router.The G1100 LAN side is cabled to the Unifi Lite 16.I replaced an RBK53 setup with the RBR850 setup in exact same topology. There has been no change to the network architecture at all. I had no problems with the RBR50 seeing it's two satellite RBS50s at each floor. The MESH worked well.
I was expecting the replacement to go smoothly and configured the RBR850 in AP mode just like my RBR50. All the satellites were detected when on the bench pre deployment. of course, they were not wired backhaul at that time. When I deployed in place of the RBK53 system, that's when the problems started. No detection of the satellites and no MESH network.Unfortunately I cant give a dedicated backhaul without going through the switch fabic.- FURRYe38Guru - Experienced User
Ok,
So if you take one RBS and directly connect it to the back of the RBR with out a switch in between. Does the RBS connect and report a wried status on the RBRs web page?
I do remember seeing a problem with the status reporting incorrectly when in AP mode when ethernet connected. I'll have to check my notes on this.
