pr5889
May 11, 2022Aspirant
Orbi RBR 853 satelite changing colors all the time. What does it mean. Also ? wired backhaul
I have an Orbi RBR 853 ( Router and two satellites) The first satellite is place about 60 ft in another room in the center of the house and also has a Cat 8 Ethernet cable used as an Ethernet back-ha...
May 11, 2022Guru - Experienced User
RBS FW updated same as the RBR?
Are the RBS directly connected via ethernet to the back of the RBR or is there a patch panel or LAN switch in between? What is the Mfr and model# of the ethernet switch in the configuration?
What CAT# LAN cable is being used between the RBR and RBS? CAT6 is recommended.
Has a power OFF of the RBR and RBS for 1 minute then back ON been performed since last FW update?
- pr5889May 11, 2022Aspirant
That's my other problem. I can't access anything. My Orbi App, or any other way will not access the Orbi. I think it's a firmware problem that others have described. Looks like I get the fun of doing a full system factory reset tomorrow. I will pay attention to the firmware number once I reset everything.
My modem is a Nighthawk CM2000
Using all Netgear hardware.
- FURRYe38May 11, 2022Guru - Experienced User
Yes a reset is needed on the RBR...
