skalman14
Jun 22, 2023Aspirant
orbi RBR 860
I have this router, and it keeps droping all the wifi items on the main wifi, even on the iot network. called netgear they do not know what to do.
also the router has the dhcp renewing the ip addr...
Jun 23, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
skalman14
Jun 25, 2023Aspirant
so i have a gateway i am not using double nat in any way or foam.
it hs the lastest software that was just out per netgear.
do not have a satelight at all.
and it is 2500 sqft
- FURRYe38Jun 26, 2023Guru - Experienced User
So if you have a gateway modem then you would be using double NAT if the modem is not put into bridge mode or your using the gateways DMZ for the RBR.
What is the actual FW version being used on the RBR?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- skalman14Jun 26, 2023Aspirant
anything else i am missing that would help?
i M READY TO PUT THE OLD ROUTER BACK IN AND TURN OFF THE WIFI AND USE THAT AS A PASS THROUGH TO THE NEW ROUTER BUT I THINK IT WILL DEFEAT THE WHOLE THING. THOUGHTS..
Firmware Version
V7.2.4.5_4.2.2no it really is just a pass thru to see the fiber
it only happens to wifi items not hard weird
2.4 ghz auto
5g 48
5ghz 2 channel 157 ( and unable to change )
changed 2.4 to channel 11
5g at the same would not let me to go 40 per the router
Hardware Version RBR860 got wifi all over the place the router can see other peoples house.
but i lose connectivity.
i got to stop the isp keeps looking for dhcp every 30 minutes is the main issue i think. but my isp says its the router.
i am ready to return this and get something else.
- FURRYe38Jun 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Try the ISP router in router mode and the Orbi system in AP mode.
I would try the beta as well:
https://www.surveymonkey.com/r/G32BGFF
Good Stuff
