skalman14
Jun 22, 2023Aspirant
orbi RBR 860
I have this router, and it keeps droping all the wifi items on the main wifi, even on the iot network. called netgear they do not know what to do.
also the router has the dhcp renewing the ip addr...
skalman14
Jun 25, 2023Aspirant
so i have a gateway i am not using double nat in any way or foam.
it hs the lastest software that was just out per netgear.
do not have a satelight at all.
and it is 2500 sqft
Jun 26, 2023Guru - Experienced User
So if you have a gateway modem then you would be using double NAT if the modem is not put into bridge mode or your using the gateways DMZ for the RBR.
What is the actual FW version being used on the RBR?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
