skalman14
Jun 22, 2023Aspirant
orbi RBR 860
I have this router, and it keeps droping all the wifi items on the main wifi, even on the iot network. called netgear they do not know what to do.
also the router has the dhcp renewing the ip addr...
bullm00n
Jun 29, 2023Virtuoso
skalman14 wrote:I have this router, and it keeps droping all the wifi items on the main wifi, even on the iot network. called netgear they do not know what to do.
also the router has the dhcp renewing the ip address every 30 min which i feel is the concern.
setup
froniter
500/500 gateway
to router nothing crazy nice and easy
anyone have a clue to help
Long shot, but easy enough to try. I had as similar issue that involved IPv6 re-upping often and causing disconnects. Turning off IPv6 helped. You might try that temporarily to see if it makes a difference.
