Rellis
Sep 28, 2021Aspirant
Orbi RBR350 - Can’t connect solar gateway
A device on my network (solar analytics gateway) communicates to a remote server using MQTT on port 443. It looks like the device is able to make a connection to the remote server, but then gets immed...
Sep 28, 2021Guru - Experienced User
You have the RBR350.
What firmware is on it?
What modem/gateway is it connected to?
Are you using armor or parental controls?
Are you using access controls?
- RellisSep 28, 2021AspirantFirmware V4.4.0.10_2.10.63_
Modem Arris CM8200
Yes I’m using Armor although the gateway device is showing as connected from my end.
No parental controls as far as I know
No access controls as far as I know
