azzkeats
Jul 08, 2023Aspirant
ORBI RBR350 - disable 5ghz for short period, or or have different SSID's
Router Firmware Version V4.4.1.29_3.10.8 HI All I am trying to connect Orbi to a door bell, that only supports 2.4ghz. Is the best option to just limit the transit power? Is there any way ...
CrimpOn
Jul 08, 2023Guru - Experienced User
Please identify this doorbell.
Nearly every consumer Internet of Things (IoT) product is equipped with the least costly WiFi radio chip, which supports only 2.4G WiFi. The Orbi 350 system provides 2.4G WiFi, so it is compatible with all of these devices.
In other words, proceed to connect the doorbell and see what happens.
azzkeats
- CrimpOnJul 08, 2023Guru - Experienced User
Thanks for the link. I see nothing in the user reviews about difficulty with setup. (other problems for sure, just not setup).
I see no reason to doubt that the Toucan app will work as expected.
What happens when you attempt to connect the doorbell.??
Notice this support article: https://www.toucansolution.com/pages/faqify
- azzkeatsJul 08, 2023Aspirant
The only thing I am seeing, is it won't pair with my phone.
I did see the message regarding only supporting 2.4ghz networks, and thought limiting my network was worth a try.
