azzkeats
Jul 08, 2023Aspirant
ORBI RBR350 - disable 5ghz for short period, or or have different SSID's
Router Firmware Version V4.4.1.29_3.10.8 HI All I am trying to connect Orbi to a door bell, that only supports 2.4ghz. Is the best option to just limit the transit power? Is there any way ...
azzkeats
CrimpOn
Jul 08, 2023Guru - Experienced User
Thanks for the link. I see nothing in the user reviews about difficulty with setup. (other problems for sure, just not setup).
I see no reason to doubt that the Toucan app will work as expected.
What happens when you attempt to connect the doorbell.??
- CrimpOnJul 08, 2023Guru - Experienced User
Notice this support article: https://www.toucansolution.com/pages/faqify
- azzkeatsJul 08, 2023Aspirant
The only thing I am seeing, is it won't pair with my phone.
I did see the message regarding only supporting 2.4ghz networks, and thought limiting my network was worth a try.
