azzkeats
Jul 08, 2023Aspirant
ORBI RBR350 - disable 5ghz for short period, or or have different SSID's
Router Firmware Version V4.4.1.29_3.10.8 HI All I am trying to connect Orbi to a door bell, that only supports 2.4ghz. Is the best option to just limit the transit power? Is there any way ...
Jul 09, 2023Guru - Experienced User
5Ghz can't be disabled. However, you might want to also change the power output of the 5Ghz radio to 25%. Under Advanced Tab/Advanced Settings/Wireless Settings. Turn OFF all RBS. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
Be sure that 20/40 MHz Coexistence enabled.
V4.4.1.29_3.10.8
HI All
Is the best option to just limit the transit power? Is there any way to rename one of the ssid's?
I have check through debug.htm, and the console is disabled on my version so that won't work.
Thanks
- azzkeatsJul 11, 2023Aspirant
Thanks, I will try that plus maybe using my phone wifi and see if that works.
I did see that option, but it did not work the first time but I think this is because I tried 10 other things first. Reset to factory settings, so back to normal now.
- FURRYe38Jul 11, 2023Guru - Experienced User
đ
