maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
CrimpOn
Sep 19, 2025Guru - Experienced User
Is this YOUR house or a rental?
hint: My solution to this situation involves a carbide drill bit to create a hole through the concrete wall for an Ethernet cable (down low, in the corner)
- maxpuissantSep 20, 2025Guide
Yes, it's our house. I might just call the electrician and see what can be done.
