maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
maxpuissant
Sep 22, 2025Guide
Hi!
Actually, I have one last question for you, because now that I think of it, it's not clear on my part:
Does the second RBS satellite communicates with the first RBS satellite? Or does it communicate only with the RBR?
Thanks!
Sep 22, 2025Guru - Experienced User
maxpuissant wrote:Does the second RBS satellite communicates with the first RBS satellite? Or does it communicate only with the RBR?
The backhaul itself can either go directly from the second RBS<->RBR or it can be daisy-chained (RBS<->RBS<->RBR). The web ui should tell you which topology you have.
As far as control goes, AFAIK Netgear has never disclosed the details.
