maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
maxpuissant
Sep 22, 2025Guide
Hi!
Actually, I have one last question for you, because now that I think of it, it's not clear on my part:
Does the second RBS satellite communicates with the first RBS satellite? Or does it communicate only with the RBR?
Thanks!
Sep 22, 2025Guru - Experienced User
For backhaul, depending of the RBS is in star formation, the RBS would connect to the RBR. If the RBR and RBS are in a daisy chain configuration, then the RBS would connect to the nearest RBS that is closer to the RBR.
When you give the power line adapter configuration a try, then the RBS wil connect to the RBR if you connect the PL adapter behind the RBR and then the other adapter to the RBS.
