maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
Sep 22, 2025Guru - Experienced User
For backhaul, depending of the RBS is in star formation, the RBS would connect to the RBR. If the RBR and RBS are in a daisy chain configuration, then the RBS would connect to the nearest RBS that is closer to the RBR.
When you give the power line adapter configuration a try, then the RBS wil connect to the RBR if you connect the PL adapter behind the RBR and then the other adapter to the RBS.
FURRYe38 wrote:When you give the power line adapter configuration a try, then the RBS wil connect to the RBR if you connect the PL adapter behind the RBR and then the other adapter to the RBS.
maxpuissant: Before you connect the RBS to the adapter, you should first connect your laptop and run a speedtest. It's important to use the same outlet pair for the adapter that you plan to use with the RBS.
