maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
CrimpOn
Oct 05, 2025Guru - Experienced User
maxpuissant wrote:installed a powerline adapter and tested it on my computer's room. I got 165 mbps, which is the lowest I had when the RBS was connected in wi-fi
As maxpuissant remarked, the only way to know if the satellite connection has switched from WiFi to 'wired' is to check the Attached Devices web page. It takes a few minutes for the system to recognize a change in connection possibilities, evaluate them, and decide which to use.
CrimpOn wrote:the only way to know if the satellite connection has switched from WiFi to 'wired' is to check the Attached Devices web page.
FWIW, I've never completely trusted that status.
If I wanted to test the performance of just a powerline link, I'd connect it directly to my pc and then run some speedtests. That way I know for sure that the powerline is the bottleneck.
