maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi! I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house. So basically, the router and the RBR350 are downstairs, ...
CrimpOn
Oct 05, 2025Guru - Experienced User
Correct. Thanks. However...... if the Attached Devices display shows 'wired Good', my impression is that it is referring to the Powerline connection (there being no physical Ethernet cable). If the Attached Devices display shows "WiFi"......
p.s. Some time ago, I spent $20 on Amazon to purchase a 100ft. CAT6 cable. When there are few family members to annoy, I can string that cable through the house (up stairs, down hallways, etc.) and connect devices to "see what happens". For example, using a temporary Ethernet cable would provide a demonstration of "what might happen" if someone drilled a hole through that concrete wall and ran an Ethernet cable through it.
