maxpuissant
Sep 19, 2025Guide
Orbi RBR350 + 2 satellites internet speed question
Hi!
I use a RBR350 Orbi connected to 2 RBS350 satellites in my house with 2 floors. There is a big concrete wall in the middle of the house.
So basically, the router and the RBR350 are downstairs, on one side of the wall. Internet speed is around 500Mb/s there.
Me and my partner are working on the 2nd floor, on two separate rooms. The best configuration I found is the following:
First satellite is on my desk, on the same side of the wall as the router and Orbi, but 2 floors above. I get around 180 Mb/s with my Macbook Pro M1 Max with an ethernet cable. A little less in WiFi.
Second satellite is on my partner's desk, on the same floor but on the other side of the wall, so I use the first satellite as a bridge to the second one. On her cheaper Asus laptop, she gets around 90 Mbs/s with ethernet.
My question is: will I be able to gain some speed at the second floor with another Orbi system? I can't have ethernet cables directly from the router ATM.
Thanks in advance.
Cheers!
Max
Humpf, just did a speed test in my room and it went up to 300Mb/s. So the signal oscillates between 180 and 300Mb/s. Not sure why so much difference.
