jpmbosco
Sep 26, 2023Aspirant
Orbi RBR350 and 2 RBS350 Firmware Issue after 4.4.1.29 upgrade
I recently brought my Orbis set up out of storage and figured that it was best to upgrade them to the latest firmware so downloaded and upgraded to 4.4.1.29. All went OK till I wanted to log in u...
- Sep 26, 2023
Look for the link at the bottom of that page that says don't have a mobile device. This will take you thru the setup wizard with the web browser.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Sep 26, 2023Guru - Experienced User
- jpmboscoSep 27, 2023Aspirant
Thanks FURRYe38, I was missing the bottom of the web page but when I scrolled down I saw the option if you do not have mobile app and have managed to fix my issues, much appreciated.
- FURRYe38Sep 27, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
