Dabsterrr
Aug 27, 2023Aspirant
Orbi RBR350 AP mode guest network improper IP Assignments
I have my RBR acting on AP only mode with 2 orbi RBS350 as nodes. Connected to the ethernet port on my RBR give me internet access. I see on my router that some devices are being assigned correctly i...
stevediaz
Hello
It seems like you're experiencing some confusion and connectivity issues with your Orbi network setup. The IP assignment mismatch between your router and the Orbi admin panel might be causing some devices to lose internet connection after a while.
To address this, you could consider adjusting the subnet on your Orbi admin panel to match the one assigned by your router (192.168.2.xxx). Additionally, checking your device settings to ensure they're properly connected to the network and not switching between different subnets might help maintain consistent connectivity.
For a more in-depth understanding and troubleshooting, the links you've provided to the Netgear community and Reddit discussions could offer valuable insights from others who have encountered similar issues. Remember, maintaining network consistency and ensuring proper device settings alignment are crucial for uninterrupted internet access.
Dabsterrr
Hi, thanks for the reply..... My orbi router is set to AP mode and configured as [attached] I cannot find the setting where I can adjust the guest network LAN settings, subnet DNS etc. Or if it's even possible. Knowledge input is very welcome 🙇‍♂️
- michaelkenwardAug 28, 2023Guru - Experienced User
Dabsterrr wrote:
My orbi router is set to AP mode and configured as [attached] I cannot find the setting where I can adjust the guest network LAN settings, subnet DNS etc. Or if it's even possible.In AP mode, that sort of thing is in the hands of the router.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
