Dabsterrr
Aug 27, 2023Aspirant
Orbi RBR350 AP mode guest network improper IP Assignments
I have my RBR acting on AP only mode with 2 orbi RBS350 as nodes. Connected to the ethernet port on my RBR give me internet access. I see on my router that some devices are being assigned correctly i...
Dabsterrr
Hi, thanks for the reply..... My orbi router is set to AP mode and configured as [attached] I cannot find the setting where I can adjust the guest network LAN settings, subnet DNS etc. Or if it's even possible. Knowledge input is very welcome 🙇‍♂️
michaelkenward
Aug 28, 2023Guru - Experienced User
In AP mode, that sort of thing is in the hands of the router.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
