EvanDunn
Mar 11, 2024Follower
Orbi rbr350 causing my modem to dropout
Hi I have all of a sudden run into a problem Orbi keeps making my modem drop internet connection constantly I have the Orbi set up in ap mode As soon as I disconnect the Orbi my modem stops drop...
Mar 11, 2024Guru - Experienced User
What do you mean by drop out of the modem?
Does the front LED on the RBR turn PINK when this happens?
What are you doing when this happens? Streaming, Downloading, Live Meeting? General Internet?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Does this happen with the RBS turned OFF?
Armor, Smart Parental Controls or Circle, Traffic Meter.
