PhenkQ
Jul 06, 2021Follower
Orbi rbr350 connected using wifi but wont connect wired
Hi, I have orbi Rbr350. I set the username and password and change vlan setting to number 2 to connect to internet. Wifi working perfectly but it wont connect wired. I can see that it give my wired...
Jul 12, 2021Guru - Experienced User
What wired device do you have connected? Connected to the RBR or the RBS?
