PhenkQ
Jul 06, 2021Follower
Orbi rbr350 connected using wifi but wont connect wired
Hi, I have orbi Rbr350. I set the username and password and change vlan setting to number 2 to connect to internet. Wifi working perfectly but it wont connect wired. I can see that it give my wired...
kin-mye
Jul 30, 2021Tutor
Yes. They told me that they will contact me when it is solved. Let's see ..
ROLgear
Jul 22, 2022Aspirant
I'm having the same problem with firmware V4.4.0.10_2.10.63, did they ever get back to you and did they solve your problem?
- kin-myeJul 22, 2022Tutor
Hi. I did not get any answer and I left the gateway router, using Orbi as AP. Not what I wanted but in fact I am having very good internet speeds, both wired and wifi in all the parts of the house.
