Ausfrenchy
Sep 25, 2021Tutor
Orbi RBR350 ethernet not working with wifi OK
Model RBR350 Firmware V4.4.0.10_2.10.63 Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection. But i cannot get hardwire ethernet connection to work at ...
- Nov 30, 2021
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
TherJ
Nov 27, 2021Aspirant
Did you get this resolved? I have similar issue.
Ausfrenchy
Nov 30, 2021Tutor
- FURRYe38Nov 30, 2021Guru - Experienced User
Good to hear. Glad NG got it fixed.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - Whitie25Dec 28, 2021TutorAny ETA on that new firmware? I’m having this issue too.
- FURRYe38Dec 28, 2021Guru - Experienced User
Contact NG support and ask for help and information regarding this.
Whitie25 wrote:
Any ETA on that new firmware? I’m having this issue too.- Whitie25Dec 31, 2021Tutor
Contacted support. Provided all the basic troubleshooting performed and linked the 3 different posts on this issue. No update today. Suspect a few people are spending their holidays troubleshooting this after getting the orbis as Xmas presents like me.
Anyone have the rumored beta firmware that resolves this?
