Ausfrenchy
Sep 24, 2021Tutor
Orbi RBR350 ethernet not working with wifi OK
Model RBR350 Firmware V4.4.0.10_2.10.63 Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection. But i cannot get hardwire ethernet connection to work at ...
- Nov 29, 2021
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
Ausfrenchy
Nov 29, 2021Tutor
Nov 30, 2021Guru - Experienced User
Good to hear. Glad NG got it fixed.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
