Ausfrenchy
Sep 24, 2021Tutor
Orbi RBR350 ethernet not working with wifi OK
Model RBR350 Firmware V4.4.0.10_2.10.63 Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection. But i cannot get hardwire ethernet connection to work at ...
- Nov 29, 2021
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
Whitie25
Dec 30, 2021Tutor
Contacted support. Provided all the basic troubleshooting performed and linked the 3 different posts on this issue. No update today. Suspect a few people are spending their holidays troubleshooting this after getting the orbis as Xmas presents like me.
Anyone have the rumored beta firmware that resolves this?
Ausfrenchy
Dec 30, 2021Tutor
Yes have the beta firmware, installed and working OK
- Whitie25Dec 31, 2021TutorIs there a link to the beta firmware? If not, would you be comfortable to email it to me?
- FURRYe38Jan 01, 2022Guru - Experienced User
You'll need to contact NG support and ask for the beta FW.
https://my.netgear.com/support/contact.aspx
Whitie25 wrote:
Is there a link to the beta firmware? If not, would you be comfortable to email it to me? - AusfrenchyJan 02, 2022Tutor
OK By me to email a copy.
Can't guarantee that your issue was the same as mine though!
- xiNeRoarJan 17, 2022Aspirant
can you send me a copy of the firmware too?
i just brought my orbi few days ago and i am having the same issue too.
feeling extremely disappoint to netgear's product...
- FURRYe38Jan 17, 2022Guru - Experienced User
- Whitie25Feb 02, 2022Tutor
Beta firmware resolves the issue. I'm running it now. But yes you will need to contact Netgear for the firmware.
