Ausfrenchy
Sep 24, 2021Tutor
Orbi RBR350 ethernet not working with wifi OK
Model RBR350 Firmware V4.4.0.10_2.10.63 Successfully set up with (PPoE) VLan and wifi performance is as good as native internet connection. But i cannot get hardwire ethernet connection to work at ...
- Nov 29, 2021
Further update on this issue.
i have just received a Beta firmware update for trial.
Looks to have fixed the problem, all working as expected now.
Whitie25
Dec 31, 2021Tutor
Is there a link to the beta firmware? If not, would you be comfortable to email it to me?
Ausfrenchy
Jan 02, 2022Tutor
OK By me to email a copy.
Can't guarantee that your issue was the same as mine though!
- xiNeRoarJan 17, 2022Aspirant
can you send me a copy of the firmware too?
i just brought my orbi few days ago and i am having the same issue too.
feeling extremely disappoint to netgear's product...
- FURRYe38Jan 17, 2022Guru - Experienced User
You'll need to contact NG support and ask for the beta FW.
https://my.netgear.com/support/contact.aspx
- Whitie25Feb 02, 2022Tutor
Beta firmware resolves the issue. I'm running it now. But yes you will need to contact Netgear for the firmware.
