satelly
May 27, 2022Aspirant
Orbi RBR350 losing 2.4 GHz signal
Recently have been moving from 1 part of the house to another which is serviced by the satellite node, I lose internet connection for about 30 seconds. Losing at the Wifi icon on my notebook, I notic...
May 27, 2022Guru - Experienced User
what firmware version are you on?
Have you tried changing which 2.4ghz channel its broadcasting on (for the router)?
satelly
On V4.4.0.10 which is apparently the latest official firmware, although reading the forum, some people have obtained newer versions from Netgear. Have tried the standard channels, 1,6 and 11with same result.
- plemansMay 27, 2022Guru - Experienced User
sounds like you've reset the satellite but did you factory reset the router?
- satellyMay 28, 2022Aspirant
Have now reset the router and problem recurred. Was searching the forum and came up with the below thread. However, before trying it, need to understand more about what the option 20/40 GHz co-existence actually does. Reading the forums, suggest it should be enabled to ensure that the 20 GHz is available so as not to affect neighbours bandwidth. If I disable it, does that mean I only get 40 GHz so if older devices with 20 Ghz can no longer connect?
- plemansMay 28, 2022Guru - Experienced User
If you live around others, leave 20/40 coexistence enabled. the 2.4ghz spectrum doesn't have many channels and the 40hz setting overlaps them. It can make your connection less stable and your neighbors.
If you live in a rural area without a lot of people around, then you can try disabling it.
