cchcng
Feb 09, 2025Follower
Orbi RBR350 lost configuration after reboot
The Orbi router(RBR350, firmware version v4.4.1.29_3.10.80) lost the configuration each time I re-boot the router. The error message when I login the Orbi App was "Orbi Not Setup". I have to go thr...
Feb 10, 2025Guru - Experienced User
as a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Then after the system is setup, save off a backup configuration to file for safe keeping:
