DavidFHob's avatar
DavidFHob
Orbi rbr350 network not connecting to LG G3 Tv
Hi, I’m having an issue connecting my G3 TV to my network - both by Ethernet or WIFI. When I connect via an Ethernet cable to a satellite (or the orbi base - same result) the error message is “no ...
  • DavidFHob's avatar
    DavidFHob
    Jan 08, 2024
    So, an update (with a happy ending!)
    LG were to send a small goods electrician out (which I later found out would have been at my cost unless they’d found a hardware problem). On discussion with them, it was clear that it was outside of their wheelhouse so they asked me to put everything in writing so they could forward it to LG again.
    LG conveniently ignored the Ethernet issue, but gave a number of directions to try to fix the WIFI problem. The solution which worked was to reset the DNS server to 8.8.8.8
    I don’t know what this does (any info would be appreciated), but I am now able to use the pretty glass screen on the wall as a television!!
