Jerome_Labla
Jan 29, 2023Aspirant
ORBI RBR350 (router) and Orbi Satellite ethernet ports not functional
My main setup :
- Netgear modem D6200
- Netgear Orbi RBR350 + 1 Satellite
- Netgear powerline 1200
- PC windows 10
- NAS Synology
Hi everyone,
I bought an Orbi pack more than one year ago in order to have a full effective wifi coverage in my apartment. It is working well and I have no issues on that part.
Back then, I tried to remove completely my former D6200 and operate only from the orbi (I have an internet cable connection). For various reason, I didn't spend enough time to get into the setup, and after several unsuccesful attempts, I left the D6200 as the main internet provider to my setup (2 PCs, one laptop, 1 NAS, an HIFI Streamer connected through powerline, and a printer), and used the Orbi only as wifi (disconnecting of course the wifi from the DS6200).
I recently decided to plug in a HIkvision camera to the ethernet port of the Orbi satellite. When directly connected to an ethernet port of the PC, the camera is well reckognised and functional.
However, when connected to the ethernet port of the satellite, the Orbi app sees the camera, but I cannot acces it from my software (through the NAS) and the included soft of HIKVision (SADPTOOL) neither. Same issue when I try to connect it to the Orbi router.
So I decided to take it further, and switched all connections from the DS 6200 to the ORBI RBR350.
1- I connected to internet cable to the internet connector of the router. The wifi worked.
2- Then I plugged my PC to the router through ethernet. It didn't work right away, but after several attempts (plug in and out on several plugs) it finaly worked.
3- Then I plugged the NAS, then a ethernet HUB (also netgear), connected to the laptop, printer, and camera.
4- I did all this without rebooting any of the devices.
5- At that point, all my deviced were visible on the mobile Orbi app and on the orbi router page from the PC browser. However, none of them were accessible (printer, NAS, camera). So only the wifi and the wire connexion to the main PC were functional.
6- I decided to reboot all the devices, and PC. That's when I also lost my wire connexion to the PC. Could'nt get it back.
7- So I checked the firmware of the orbi, downloaded to last version. No change.
8- Finally I reseted to factory settings the Orbi, reinstalled the app and setup. And at this point, not only everything was still not functional, but I also lost the internet cable connexion :))))))).
9- I did all this after and while reading info on internet, but nothing helped.
10- So I went back to my initial setting : DS6200 for ethernet and internet connexion, and Orbi for wifi.
Frustration is at a maximum as you can imagine.
But still, my 2 issues are not soved :
a- why my camera is not functional from the ethernet port of the satellite
b- Why most of the ethernet ports of the router are not functional, or randomly ?
Sorry for this long story, I wanted to give you a detailed description.
I didn't talked to the Netgear support yet, my experience is that often, the community react quicker and more efficiently than the support team.
Have a nice Sunday,
Jérôme
The D6200 is a combination DSL modem/router/WiFi device. It is important to know how it is connected to the Internet Service Provider (ISP): https://www.downloads.netgear.com/files/GDC/D6200/D6200_IG_NA_Cover+Interior_20Oct2014.pdf
Does it connect to a phone splitter or using an Ethernet cable? (If it connects to a phone splitter, then it cannot be removed.)
In general, when adding a new router, every device should connect to the new router. This keeps them all on one local area network (IP subnet) where they can all "see" and communicate with each other.
- Jerome_LablaAspirant
Thanks for your quick answer.
The D6200 is connected through an Ethernet cable, not phone splitter.
I wonder if there can be any consequences on the fact that the Hikvision camera is not functional when connected to the ethernet port of the Orbi Satellite (though the mapping on the orbi mob app shows it) ?
Another information : the camera has a fixed IP 192.168.0.30. But in the mapping of the orbi mobile app, it shows 192.168.0.64.
Jérôme
In this case, the D6200 can be removed, leaving a single router (the Orbi), with every device connected to it.
Static IP address is a bit ambiguous.
- The traditional meaning is that the user has configured this IP address on the physical device itself. In this case, the device will accept only communications directed to that specific IP address. And, the IP subnet and gateway IPs have to be set correctly for the device to know how to communicate with other devices.
- What most Orbi users do is define a Reserved Address using the LAN Setup table in the router web interface. That way, when the device is powered on and uses the DHCP process to request an IP address, we can be confident that it will always get the same address from the router. There are some nuances in this process. Reserved Addresses should be separate from the "pool" of IP addresses used for other device. Also, Orbi's have a quirky DHCP mechanism and sometimes devices stubbornly keep using the same IP address until the router itself is turned off and on again. (A chore that I hate to do.)
I would try setting the camera to use DHCP to get an IP address like everything else does.
