AdamNipperess
Nov 27, 2022Aspirant
Orbi RBR350 Satellite connection issue since firmware version V4.4.1.29 upgrade
I have no idea what Netgear have done but since I upgraded my Orbi RBR350 to firmware version 4.4.1.29! Every time I connect the satellite to the Orbi router I can not connect all my devices to the W...
Nov 28, 2022Guru - Experienced User
did you try reconnecting the satellite after the factory reset? Sometimes old settings can cause issues.
And are you sure the satellite updated as well? Sometimes if you update the router first and not the satellite, it can cause issues.
And if neither of those work, you can always downgrade the firmware.
AdamNipperess
Nov 28, 2022Aspirant
Yes I have tried reconnecting to satellite since the update and still having then same issue.
I confirmed the update on both devices via the settings link not the app. Both of them have the latest version.
