Wishawpubs
Jan 18, 2022Aspirant
Orbi RBR350 Satellite constant white flashing light
On Sunday night I wanted to attached the my Orbi RBR350 to another router for testing purposes. I switched the device from router to AP mode. After the switch one of the 2 satellites wouldn't reconne...
- Jan 18, 2022
Ya if it won't re-sync wirelessly with older and most current, something on the RBS is faulty. Needs replacing. Contact NG support and ask about an RMA:
Wishawpubs
You can click on the link but nothing happens.
I've actaully just managed to flash firmware 4.3.4.8 onto the device using Tftpd. But won't connect.
Flashed back to 4.4.0.10, and still no connection.
I'm suspecting a hardware fault.
Wishawpubs
Logged onto the working satellite via 192.168.1.250 using a LAN cable and the status screen shows the wireless networks.
To me this show signs of a hardware fault.
- FURRYe38Jan 18, 2022Guru - Experienced User
