Pauldennis's avatar
Pauldennis
Orbi RBR350 Satellite to Satellite
Both Satellites connect to the main RBR350 Router, however due to the distance from the main router to the 2nd satellite it keeps loosing it's signal - how can I force the 2nd satellite to connect to the 1st satellite ?
1 Reply
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
    Thank you.
