ROLgear
Jul 21, 2022Aspirant
Orbi RBR350 wired connections and internet constantly dying
Since the last 2-3 weeks my Orbi RBR350 keeps going down. Purple light off and on, Virgin Media tests showing all is fine. Reboot of Virgin Hub 3 then Orbi solves it. But my wired satellite doesn't...
Jul 21, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first.
- ROLgearJul 22, 2022Aspirant
Thanks, the Virgin hub has been in modem only mode since I got the Orbi so there shouldn't be a double NAT condition as it's not assigning IPs or has wifi etc. I had made no changes to anything before the problem (no settings or hardware changes) so am hoping it's a firmware issue.
I've performed a factory reset on the Orbi and crossing my fingers that it fixes things...
- FURRYe38Aug 13, 2022Guru - Experienced User
Any progress on this?
- ROLgearAug 16, 2022Aspirant
I got hold of the Beta but I still had problems with the wired LAN. I thought it was one of my devices which had a corrupted network settings file but after making changes it still happened.
Now I suspect it may be that I'm using a USB-C hub with ethernet - I think that sometimes when I connect/disconnect my Macbook it doesn't like it. Odd as that ethernet cable is not directly linked to my Orbi but instead goes via a (brand new) ethernet hub.
