ROLgear
Jul 21, 2022Aspirant
Orbi RBR350 wired connections and internet constantly dying
Since the last 2-3 weeks my Orbi RBR350 keeps going down. Purple light off and on, Virgin Media tests showing all is fine. Reboot of Virgin Hub 3 then Orbi solves it. But my wired satellite doesn't...
ROLgear
Jul 22, 2022Aspirant
Thanks, the Virgin hub has been in modem only mode since I got the Orbi so there shouldn't be a double NAT condition as it's not assigning IPs or has wifi etc. I had made no changes to anything before the problem (no settings or hardware changes) so am hoping it's a firmware issue.
I've performed a factory reset on the Orbi and crossing my fingers that it fixes things...
Aug 13, 2022Guru - Experienced User
Any progress on this?
