guyscottsouth
Sep 07, 2022Aspirant
Orbi RBR350
We have a long house and with the router at the front and 3 satellites, the system doesn't seem to be daisy chaining them however, I'm not sure if i've done something wrong in the setup, but they are all connected to the router with progressively weaker signals
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Daisy Chain is automatic on Orbi AX systems. Based on placement to the RBR and RBS out in a line and how they are turned on will determine how they get connected in Daisy Chain layout.
- guyscottsouthAspirant
Thanks, I moved the first satelite slightly further away and it seems to be working much better
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
