Koldur
May 01, 2022Tutor
Orbi RBR353 seperate 2.4 and 5GHz SSIDs
I have tried to turn on Telnet in the debug page, but it is not available anymore on newer firmwares I have come to understand. So is there any new/other way to seperate both bands SSIDs? The issue i...
- May 01, 2022
OK. It is not possible. Sorry. Return it.
Koldur
May 01, 2022Tutor
Unfortunately, this is not the case. It is a widespread problem and it is not an Orbi isolated problem. I am a pretty knowledgeable person about this kind of stuff and have done extensive research on this issue and have a lot of experience with these issues. Never knew the Orbi couldn't handle seperate SSIDs.
Either way, whatever is the case, with the devices I have issues with there, the problem goes away when the 5GHz band is disabled, the issues are gone. But that isn't a good solution 😉
CrimpOn
May 01, 2022Guru - Experienced User
What would be the model of phones that have only 2.4G WiFi and cannot connect to an Orbi when the 5G WiFi is enabled?
