RobDal
Aug 26, 2024Follower
Orbi RBR50 Satellite not working as measured
I wanted to test the satellite before I moved it upstairs. For testing I have the Orbi RBR50 router in my den and am using a WiFi signal strength app. The dBm app range is -70 to -10. When I am ...
Aug 26, 2024Guru - Experienced User
Be sure that your testing device(s) is connected to the RBS. Check the RBS web page to see if anything is connected at the RBS.
Disable any wifi radios on wifi devices for 10 seconds then re-enable while the device is nearest to the RBS. Some device will maintain connections to the RBR or other wifi signals and won't connect to the nearest signal unless you disable the wifi radio on the device.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
