Matsurigatzu
Sep 03, 2022Aspirant
Orbi RBR50
I currently have the RBR50 as my main router that is connected directly to my modem. I am looking at purchasing and adding one additional satellite. The model for that is AX4200. Will that work with ...
- Sep 03, 2022
Not compatible.
Matsurigatzu
Thank you for the incredibly fast response. I was worried that would be the answer. Now the big question is should I completely get the new Orbi system or go on Amazon and buy a refurbished satellite that works with my current system?
Sep 03, 2022Guru - Experienced User
Would be up to you. IF your current system works for you, you might just add something that works.
