bldewitt's avatar
bldewitt
Orbi RBR750 - Intermittent Drops and Unable to Connect to Google
Hello,   I have an Orbi RBR750 AX4200 with one satellite. Over the past week, we have experienced intermittent drops and issues connecting to and staying consistently connected to the wifi. The iss...
  • FURRYe38's avatar
    Mar 21, 2023
    Does this happen with wired devices as well?
    Does the front LED on the RBR turn PINK any when this happens?
    What mode is the FIOS gatway working in? Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
    What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
