Ninjakeks_5
Aug 16, 2021Tutor
Orbi RBR750 - Interruptions on WEBEX & MS Teams Calls
Hey guys I've recently installed my Orbi system (RBR750; one satellite). It's attached to a cable modem which I've set to bridge mode. I'm having since then trouble on every WEBEX or MS Teams Ca...
- Aug 16, 2021
Could try this this, put the modem back in to router mode and configure the RBR for AP mode. See if the problem continues...
Ninjakeks_5
Aug 16, 2021Tutor
Hi FURRYE38
Firmware: V4.6.3.7_2.0.49
ISP Modem: ARRIS TG3492LG-LC
Sq Ft Home: 1400
Distance R and S: 50 Ft
20/40Mhz Coexistence: Disabled
CTS: Set to 2347 for 2.4 GHz & 5 GHz (see attachment)
AX: Not disabled - I have a specific antenna for AX mode on my PC
Can you tell me what the 20/40Mhz Coexistence and the CTS setting to 2347 does?
Is the issue Firmware related?
I've tested it quickly with two call and noticed some drops. I'll have to test it during the coming days on a proper call. Keep you updated.
Regards
NJ
Aug 16, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Distance R and S: 50 Ft< you might try the RBS a bit closer and see. Try 40 feet?
Most likely FW related hwoever lets see if we can help this out for now. Unfortuately we can't downgrade from v4 to v3.
