Ninjakeks_5
Aug 16, 2021Tutor
Orbi RBR750 - Interruptions on WEBEX & MS Teams Calls
Hey guys I've recently installed my Orbi system (RBR750; one satellite). It's attached to a cable modem which I've set to bridge mode. I'm having since then trouble on every WEBEX or MS Teams Ca...
- Aug 16, 2021
Could try this this, put the modem back in to router mode and configure the RBR for AP mode. See if the problem continues...
Ninjakeks_5
Aug 16, 2021Tutor
Hi FURRYe38
ISP Modem is already in bridge mode. About the Distance R and S; they almost have a direct sight with no wall in-between. I have the issue even when connected to the router and not only to the satellite.
Regards
NK
Aug 16, 2021Guru - Experienced User
- Ninjakeks_5Aug 18, 2021Tutor
It looks like that it's helping. I'll neet to test it on the "big" calls tomorrow.
Any insight if this will be solved soon? I don't want do use the ISP modem as a router, it's not really good...
Kind regards
Alex
- FURRYe38Aug 18, 2021Guru - Experienced User
NG is aware of problems on recent version of FW. They don't give information on when new FW will be forth coming.
Hopefully soon though. Please be patient.
- Ninjakeks_5Aug 19, 2021Tutor
No issues today, hopefully the new FW will resolve this issue.
One last question, what does the following settings do?
"Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347"
