TMACC
Oct 26, 2024Follower
Orbi RBR750 - Samsung TV will not connect to WiFi
I have Fiber Internet (ATT BGW320-500 Router) and connected my Orbi RBR750 Router to it. Everything connects to the Orbi WiFi without an issue. However, when I try to connect my Samsung TV to the Orb...
Oct 26, 2024Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
