spextreme
Jan 21, 2025Aspirant
ORBI RBR750 - Satellite will not connect
I've been stuck on this for a while, scoured the web for anything, and tried them all. I purchase the ORBI system back in June of 2024. When I got them I set up the router and connected the satelli...
Jan 21, 2025Guru - Experienced User
What model RBS do you have? Save FW version on the RBS?
spextreme
Orbi router rbr750 and satellite rbs750.
- spextremeJan 21, 2025AspirantAs for firmware on the satellite I don’t know how to find that out without a connection to it. If you can guide I can find out
- FURRYe38Jan 21, 2025Guru - Experienced User
Try this PDF process:
This looked promising but I've tried multiple times following the steps and I can not connect to the satellite. I have a Linux laptop so I set that up to use the defined wired connection ip/subnet. Reset the satellite, and then powered it off. After powering on, around 3 minutes, the light turned blue and a web page connected to the IP says can't be reached. I'm stuck there and not sure why this isn't working. Are there any other things I should try?
