frlonet
Aug 26, 2021Aspirant
Orbi RBR750 - scanning attacks?
Hi everyone, thanks so much in advance for any assistance on this. I have my Orbi AX4200, been set up for a few months. I have upgraded to the v4.6.3.7 firmware, and I'm aware that a few problems are...
Aug 28, 2021Guru - Experienced User
Ok, no router at the modem.
Keep us posted...
frlonet
Aug 28, 2021Aspirant
Thanks, sorry I'm not sure what you mean by no router at the modem. Isn't my Orbi the router? I'm not an expert with this stuff :(
Also with regards to your suggestion about disabling Armor and seeing if it happens again, how would I know if it happens because Netgear Armor is supposedly the thing that sends me the notifications on the app?
Aside from all this, any theories at this stage? While the outages are annoying, it doesn't bother me as much as not knowing. Is it likely just a false positive, any similar behavior like this? I know the latest Orbi firmware seems to have some issues. Thanks!!
- FURRYe38Aug 29, 2021Guru - Experienced User
Review the RBR logs on it's web page...
- FURRYe38Jan 29, 2022Guru - Experienced User
Any progress on this?
- frlonetJan 29, 2022Aspirant
Hey, no real progress in the sense that I never found any information. In the logs, it showed nothing, no dropouts or reconnections or anything. Same thing, just "attack" then the internet drops. No information on the attack, no change in the devices wifi logs, or the admin logs.
- FURRYe38Jan 30, 2022Guru - Experienced User
Maybe something on your detected device that Armor is finding. Though not sure what it would be.
Does this happen if you disable Armor?
You might try new FW listed in this forum though not sure if it would be helpful.
